Export KMZ with filter does not work
736
01-29-2024 06:36 AM
StephM
Hello community 🙂
I have an issue about spatial query on MapService.
I'm sending a polygon geometry to the query (representing an area) and I want to retrieve points inside that area (intersects).
Everything is OK for all formats ... the only issue I have is with the KMZ.
After some tries, I could say that the export KMZ use the bounding box of the polygon sent to the query.
Do you have any clue about that ?
Thanks for your time and help.
Best regards
