ESRI javascript internal
1687
09-16-2013 08:05 AM
vinayb
HI All,
I am using ESRI javascript for my application which also has lot of other stuffs along with map , i this.navigationManager  is undefined in IE and mozilla and  'disableNavigation' of undefined  , any clue how can i avoid it , i am using 3.6 version of javascript api.
vinayb
Resolved this issue by local loading js api.
JonathanUihlein
VinayBa, it would be extremely helpful for other users if you would go back and mark your previously created threads as answered when an answer has been provided.
You've created thirty different threads, and all of them are currently marked as open:
http://forums.arcgis.com/search.php?searchid=1736844
It would also be helpful to post how you went about fixing your problem(s) so future users who search the forums can find them.
Thank you!
vinayb
sure thank you, i am not find option to do that
KenBuja
MVP Esteemed Contributor
Take a look at this page about how to use the check mark and arrows to signify that a post answered your question or was helpful.
vinayb
