Error SSL when adding proxy .Net in arcgis api js
970
03-14-2022 02:04 PM
benchikh
Hi
Actually Im working to integrate a proxy with .Net, and I have followed some examples on how to do that. but unfortunately I am not able to figure it out.
so I will explain what I have did:
1- I have downloaded the .Net proxy folder from the internet and have host it on my IIS, so I have test it and all looks OK
2- next, I have updated my proxy.config file as below
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
mustMatch="true">
<serverUrls>
<serverUrl url="https://domaine.ma/arcgis2/rest/services/JOUR/FeatureServer/"
matchAll="true"/>
</serverUrls>
</ProxyConfig>
3 - finally, I have added on my index js page the following code
urlUtils.addProxyRule({
urlPrefix: "https://domaine.ma/arcgis2/",
proxyUrl: "/ingPro/proxy.ashx"
so when I call my service, I got the below error
  1. code: 500
  2. message: "La connexion sous-jacente a été fermée : Impossible d'établir une relation de confiance pour le canal sécurisé SSL/TLS. https://domaine.ma/arcgis2/rest/services/JOUR/FeatureServer/0?f=json"
So could you please help me with the above error ?
Many thanks in advance
Noah-Sager
I don't think we promote using the Esri proxy anymore, but it looks like since you're calling from localhost over http, and the resources are accessible via https, that's the issue. If the app was hosted over https, then that might resolve the error.
