Error in retrieving records for table
838
03-13-2023 07:23 AM
kapalczynski
I have a weird issue... I inherited an app that was created before my time.
I can run the app and load all the layers.  There is a specific polygon layer in there that is only 733 records.  If I view the map at full scale and then open the attribute table it spins but then seems to time out as the records do not appear.
If I zoom in a bit it loads the appropriate records from that zoom level but if I request all the records (only 733) it stalls out and give me the query error
Console says this
Sources Says this:
So I started thinking a time out or something....
This is the Service that is having the issues.... Although the error is thrown at about 30 seconds.
I tested 600 seconds in the 2nd option below and no difference
NOTE: this application is not residing in AGOL or Portal its was donwloaded into our IIS and hosted from there.....
Does anyone have any ideas on what to check?
kapalczynski
I did an obnoxious Generalize on the polygons of 1000 meters and when I checked there was no more issue in the application.  It appears that although only 733 records (which span across the whole state) the geometries were to complex / too many nodes....
kapalczynski
I read this but again this is just 733 polygon features....The geometry renders fine in the map and is responsive but the table blows up.  If I zoom in and say 190ish records the table loads those... but even at that scale I want to see all the records and hit the button to return all the records regardless of scale and it blows up
https://support.esri.com/en/technical-article/000011736
kapalczynski
