Error in Draw Measurement
832
10-04-2022 02:20 AM
Nikarayanpouya
HI
I'm having trouble using the measurement
When drawing the Asia_North_Lambert_Conformal_Conic geographical system measurement,
it gives the following error:
spatialReference Object { wkt: "PROJCS[\"Asia_North_Lambert_Conformal_Conic\",GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Lambert_Conformal_Conic\"],PARAMETER[\"False_Easting\",0.0],PARAMETER[\"False_Northing\",500.0],PARAMETER[\"Central_Meridian\",54.0],PARAMETER[\"Standard_Parallel_1\",30.0],PARAMETER[\"Standard_Parallel_2\",36.0],PARAMETER[\"Latitude_Of_Origin\",24.0],UNIT[\"Meter\",1.0]],VERTCS[\"WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PARAMETER[\"Vertical_Shift\",0.0],PARAMETER[\"Direction\",1.0],UNIT[\"Meter\",1.0]]" }
