Dynamic templatePicker based on user-chosen layer
1071
08-11-2013 12:26 PM
by Anonymous User
Not applicable
Looking for advice on having multiple layers eligible for editing yet allowing user which to edit a layer based on, say, a pulldown menu. In this case, there are as many as 15 layers which may need editing. However I'd like to populate the templatePicker with only a user-chosen layer.
Thanks in advance,
rGibson
KellyHutchins
Esri Notable Contributor
Russell,
You can do this using a combination of TemplatePicker.set and TemplatePicker.update. Here's a link to a fiddle that shows a proof of concept:
http://jsfiddle.net/xM7f4/
KellyHutchins
Russell,
by Anonymous User
Not applicable
Great stuff, Kelly. Thanks!
I actually ended up making it work with something like....(partial code)
function fireEd()
        map.removeAllLayers();
        var myLyrList=document.getElementById("myList");
edLayer = myLyrList.options[myList.selectedIndex].text;
map.addLayer(basemap);
     map.addLayers([bldgInteriorFloor1,camerasBasement,doorsBasement,securityBasement,stairsElevBasement]);
      function initEditor(results) {
      if (templatePicker)
     templatePicker.destroy();
     dojo.create("div", {id: "templateDiv"}, "cPane");
   if (myEditor)
     myEditor.destroy();
           dojo.create("div", {id: "editorDiv"}, "cPane");
      for (var i=0;results;i++)
     if (results.layer.name == edLayer)
       results = [results];
      var templateLayers = dojo.map(results,function(result){
            return result.layer;
