Draw Point Line Poly and get its geometry
4463
09-08-2022 10:01 AM
jaykapalczynski
Honored Contributor
I am trying to have a simple map and:
  1. Allow the user to draw a point, line, or polygon.  Although just 1.
  2. I then need to buffer this feature
  3. I then need to capture its geometry so I can send that as a parameter to a GP Tool
I looked at this widget https://developers.arcgis.com/javascript/latest/sample-code/sketch-geometries/  but could not figure out how to limit it to one geometry in the graphics layer.  I assume that I could just remove all features every time the user clicks the map.  Or someway to disable the widget after each feature creation in the map (Then deleting all features next time the widget is used?)
I am not sure the widget is the way to go and looking for some thoughts or examples for this.
The widget stores geometry in the graphics layer so If I could control the layer to only have 1 feature at a time I could query the graphics layer for its geometry....
Thoughts?
jaykapalczynski
Honored Contributor
Got it... Sorry to waste your time... If anyone can benefit then great..
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>Draw polyline | Sample | ArcGIS API for JavaScript 4.24</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.24/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.24/"></script>
    <style>
      html,
      body,
      #viewDiv {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script>
  require([
    "esri/Map",
    "esri/views/MapView",
    "esri/views/draw/Draw",
    "esri/Graphic",
    "esri/geometry/geometryEngine"
  ], (Map, MapView, Draw, Graphic, geometryEngine) => {
    const map = new Map({
      basemap: "gray-vector"
    const view = new MapView({
      container: "viewDiv",
      map: map,
      zoom: 15,
      center: [18.06, 59.34]
    // add the button for the draw tool
    view.ui.add("line-button", "top-left");
    view.ui.add("point-button", "top-left");
    view.ui.add("polygon-button", "top-left");
    const draw = new Draw({
      view: view
   document.getElementById("point-button").onclick = () => {
      view.graphics.removeAll();
      // creates and returns an instance of PolyLineDrawAction
      const action = draw.create("point");
      // focus the view to activate keyboard shortcuts for sketching
      view.focus();
     // PointDrawAction.cursor-update
      // Give a visual feedback to users as they move the pointer over the view
      action.on("cursor-update", function (evt) {
        updateVerticesPoint(evt.coordinates);
      // PointDrawAction.draw-complete
      // Create a point when user clicks on the view or presses "C" key.
      action.on("draw-complete", function (evt) {
    document.getElementById("polygon-button").onclick = () => {
      const action = draw.create("polygon");
      view.focus();
      // listen polylineDrawAction events to give immediate visual feedback
      // to users as the line is being drawn on the view.
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
        updateVerticesPolygon
    // draw polyline button
    document.getElementById("line-button").onclick = () => {
      const action = draw.create("polyline");
      view.focus();
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
        updateVerticesLine
    function updateVerticesPoint(coordinates) {
      //// create a polyline from returned vertices
      //if (event.vertices.length > 0) {
      //  const result = createGraphicPoint(event);
  let point = {
    type: "point", // autocasts as /Point
    x: coordinates[0],
    y: coordinates[1],
    spatialReference: view.spatialReference
      let graphic = new Graphic({
        geometry: point,
        symbol: {
          type: "simple-marker", // autocasts as SimpleMarkerSymbol
      style: "square",
      color: "red",
      outline: { // autocasts as SimpleLineSymbol
        color: [255, 255, 0],
        width: 3
  view.graphics.add(graphic);
    // Checks if the last vertex is making the line intersect itself.
    function updateVerticesPolygon(event) {
      if (event.vertices.length > 1) {
        const result = createGraphicPolygon(event);
    function updateVerticesLine(event) {
        const result = createGraphicLine(event);
        // if the last vertex is making the line intersects itself,
        // prevent the events from firing
        if (result.selfIntersects) {
          event.preventDefault();
    function createGraphicPoint(event) {
      const vertices = event.vertices;
      // a graphic representing the polyline that is being drawn
      const graphicPoly = new Graphic({
        geometry: {
          type: "point",
        symbol: {
          type: "simple-marker", // autocasts as new SimpleFillSymbol
          color: [227, 139, 79, 0.8],
          outline: {
             color: [255, 255, 255],
             width: 1
      view.graphics.add(graphicPoly);
    // create a new graphic presenting the polyline that is being drawn on the view
    function createGraphicPolygon(event) {
        geometry: {
          type: "polygon",
          rings: vertices,
        symbol: {
          type: "simple-fill", // autocasts as new SimpleFillSymbol
          outline: {
             width: 1
    function createGraphicLine(event) {
      const graphicLine = new Graphic({
        geometry: {
          type: "polyline",
          paths: vertices,
        symbol: {
          type: "simple-line", // autocasts as new SimpleFillSymbol
          color: [4, 90, 141],
          width: 4,
          cap: "round",
          join: "round"
      // check if the polyline intersects itself.
      const intersectingSegment = getIntersectingSegment(graphicLine.geometry);
      // Add a new graphic for the intersecting segment.
      if (intersectingSegment) {
        view.graphics.addMany([graphicLine, intersectingSegment]);
      // Just add the graphic representing the polyline if no intersection
      else {
        view.graphics.add(graphicLine);
      // return intersectingSegment
      return {
        selfIntersects: intersectingSegment
    // function that checks if the line intersects itself
    function isSelfIntersecting(polyline) {
      if (polyline.paths[0].length < 3) {
        return false;
      const line = polyline.clone();
      //get the last segment from the polyline that is being drawn
      const lastSegment = getLastSegment(polyline);
      line.removePoint(0, line.paths[0].length - 1);
      // returns true if the line intersects itself, false otherwise
      return geometryEngine.crosses(lastSegment, line);
    // Checks if the line intersects itself. If yes, change the last
    // segment's symbol giving a visual feedback to the user.
    function getIntersectingSegment(polyline) {
      if (isSelfIntersecting(polyline)) {
        return new Graphic({
          geometry: getLastSegment(polyline),
          symbol: {
            type: "simple-line", // autocasts as new SimpleLineSymbol
            style: "short-dot",
            width: 3.5,
            color: "yellow"
      return null;
    // Get the last segment of the polyline that is being drawn
    function getLastSegment(polyline) {
      const lastXYPoint = line.removePoint(0, line.paths[0].length - 1);
      const existingLineFinalPoint = line.getPoint(
        0,
      return {
        type: "polyline",
        spatialReference: view.spatialReference,
        hasZ: false,
        paths: [
            [existingLineFinalPoint.x, existingLineFinalPoint.y],
            [lastXYPoint.x, lastXYPoint.y]
</script>
  </head>
  <body>
    <!-- https://developers.arcgis.com/javascript/latest/esri-icon-font/ -->
    <div id="viewDiv">
      <div id="point-button" class="esri-widget esri-widget--button esri-interactive" title="Draw point">
        <span class="esri-icon-map-pin"></span>
      </div>
      <div id="line-button" class="esri-widget esri-widget--button esri-interactive" title="Draw polyline">
        <span class="esri-icon-polyline"></span>
      </div>
      <div id="polygon-button" class="esri-widget esri-widget--button esri-interactive" title="Draw polygon">
        <span class="esri-icon-polygon"></span>
      </div>
    </div>
  </body>
</html>
jaykapalczynski
Honored Contributor
OK I am trying this solution... It has the Line working I am now trying to incorporate the Polygon add...
Not sure where I am failing
<html>
  <head>
    <style>
      html,
      body,
      #viewDiv {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script>
  require([
    "esri/Map",
    "esri/Graphic",
      map: map,
      zoom: 15,
      view: view
      view.focus();
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
      view.focus();
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
        updateVerticesLine
        geometry: {
          type: "polygon",
          paths: vertices,
        symbol: {
          outline: {
             width: 1
        geometry: {
          type: "polyline",
          paths: vertices,
        symbol: {
          width: 4,
          cap: "round",
          join: "round"
      else {
      return {
        return false;
          symbol: {
            style: "short-dot",
            width: 3.5,
            color: "yellow"
      return null;
        0,
      return {
        type: "polyline",
        hasZ: false,
        paths: [
</script>
  </head>
  <body>
    <div id="viewDiv">
      </div>
      </div>
      </div>
    </div>
  </body>
</html>
jaykapalczynski
Honored Contributor
OK I got the polygon to draw...  Needed    RINGS: vertices,
Just need to figure out the point
geometry: {
type: "polygon",
rings: vertices,
jaykapalczynski
Honored Contributor
<html>
  <head>
    <style>
      html,
      body,
      #viewDiv {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script>
  require([
    "esri/Map",
    "esri/Graphic",
      map: map,
      zoom: 15,
      view: view
      view.focus();
      view.focus();
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
      view.focus();
      action.on(
          "vertex-add",
          "vertex-remove",
          "cursor-update",
          "redo",
          "undo",
          "draw-complete"
        updateVerticesLine
  let point = {
    x: coordinates[0],
    y: coordinates[1],
        geometry: point,
        symbol: {
      style: "square",
      color: "red",
        width: 3
        geometry: {
          type: "point",
        symbol: {
          outline: {
             width: 1
        geometry: {
          type: "polygon",
          rings: vertices,
        symbol: {
          outline: {
             width: 1
        geometry: {
          type: "polyline",
          paths: vertices,
        symbol: {
          width: 4,
          cap: "round",
          join: "round"
      else {
      return {
        return false;
          symbol: {
            style: "short-dot",
            width: 3.5,
            color: "yellow"
      return null;
        0,
      return {
        type: "polyline",
        hasZ: false,
        paths: [
</script>
  </head>
  <body>
    <div id="viewDiv">
      </div>
      </div>
      </div>
    </div>
  </body>
</html>
