dojo/parser::parse() error Error: string.substitute could not find key "loadingState" in template
2896
06-06-2018 07:08 AM
SriHarsha
hi  I am unable to handle  dojo parser  while accessing on development environment  everything working fine bu at stating environment I am getting error   "dojo/parser::parse() error Error: string.substitute could not find key "loadingState" in template"
DavidCooke
FWIW: I've found the error can be triggered when the pages language is set (e.g. <html lang="en">).  I've encountered this when using API version 3.26 and dojox/grid/EnhancedGrid.
RajeevRoy
According to AODA recommendation "lang" attribute should be added with <html> tag. But if we add the "lang" attribute, then we are facing the same issue. We are using ArcGIS Javascript API 3.3.
Please let us know how we can handle this issue.
RobertScheitlin__GISP
Using the proper value works fine:
<html lang="en-US">
