Do I have to cleanup DrawAction event listeners after completion?
838
12-13-2024 02:15 PM
GHvW33
When I create one of the various DrawActions via Draw. If the action completes, do I still need to clean up the event listeners I set up via the `.on()` method, or will those get cleaned up automatically upon completion?
ReneRubalcava
Esri Frequent Contributor
Yeah, any listeners you create with "on" you need to clean up. The "on" method returns an object with a "remove()" method you can use for that.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-draw-DrawAction.html#on
