Display features on side panel esri Javascript API 4.3
7207
15
03-30-2017 02:26 PM
Naga_RaghuveerModala
Is there any example that I can use to display features on side panel using Javascript API 4.3 ?
BarbaraPutnam1
In the 4.3 api I don't see  'esri/symbols/support/symbolPreview', The only object under esri/symbols/support is JsonUtils. Where did you find symbolPreview?   It sounds like it will generate the SVG descripter from an input symbol or graphic which is what I want to do. Thanks
RobertScheitlin__GISP
Babara,
   It is a class that has not be documented yet. I spoke the the dev team about this last month at the Dev Summit.
BarbaraPutnam1
Is it in the 4.3 api currently?  When I try to reference it from my app, it says it can't be found. Is there a way to get ahold of the code if its not in the package?   Thanks
Barbara,
  Yes it is part of 4.3 (it is just not documented). Thomas gives examples of how to add it to your requires and some basic code for it's use above.
ThomasSolow
Yeah, like Robert said, it's not in the SDK documentation, but it is in 4.3.
You can pull it in the same way you'd pull in any other module: JS Bin - Collaborative JavaScript Debugging
BarbaraPutnam1
Thanks Thomas and Robert!,
