Disable scaling feature in Editor widget
2139
05-27-2024 03:31 AM
achyl
Hi, how can i disable scaling in editor widget?
I would like to disable scaling for CityFurnitureLayer when creating and updating.
const editor = new Editor({
  view: view,
  layerInfos: [
    CityFurnitureInfos(CityFurnitureLayer, content),
    VegetationInfos(VegetationLayer, content),
    BaseInfos(BaseLayer, content),
    PathInfos(pathLayer, content),
  tooltipOptions: { enabled: true },
  labelOptions: { enabled: true }
export const CityFurnitureInfos = (CityFurnitureLayer, content) => {
  return {
    layer: CityFurnitureLayer,
    formTemplate: {
      elements: [
          type: 'field',
          fieldName: 'TYPE',
          label: content.furnitureInfos.labelType
          type: 'field',
          fieldName: 'SIZE',
          label: content.furnitureInfos.labelSize,
          formatter: function (value) {
                return value.toFixed(2);
              format: {
                places: 2,
                digitSeparator: true
              editorType: 'number'
          type: 'field',
          fieldName: 'ROTATION',
          label: content.furnitureInfos.labelRotation,
    fieldInfos:  [{
        fieldName: 'SIZE',
        format: {
          places: 2,
Jan62
We have the same problem. It seems, only 4.29 is affectet under 4.28 it works fine. The the Sandbox Code.
4.28 Works as intended
<html lang="en">
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Edit features with the Editor widget | Sample | ArcGIS Maps SDK for JavaScript 4.29</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.28/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/WebMap",
        "esri/views/MapView",
        "esri/widgets/Editor"
        WebMap, MapView,
        Editor
        // Create a map from the referenced webmap item id
        const webmap = new WebMap({
          portalItem: {
        const view = new MapView({
          container: "viewDiv",
          map: webmap
        view.when(() => {
            view: view,
          editor.viewModel.sketchViewModel.defaultUpdateOptions.enableRotation  = true;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.enableScaling  = false;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.enableZ  = false;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.multipleSelectionEnabled = false;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.preserveAspectRatio  = true;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.toggleToolOnClick = false;
          editor.viewModel.sketchViewModel.tool = "transform";
          // Add the widget to the view
          view.ui.add(editor, "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
4.29 Overrides the defaults and enables scaling
<html lang="en">
<head>
  <script src="https://js.arcgis.com/4.29/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/WebMap",
        WebMap, MapView,
        Editor
          portalItem: {
          map: webmap
        view.when(() => {
            view: view,
  </script>
</head>
<body>
</body>
</html>
JoelBennett
MVP Regular Contributor
You can disable scaling on updates like so:
Unfortunately, the defaultCreateOptions provide no such property.   They do have a preserveAspectRatio property though which may be helpful, as does defaultUpdateOptions:
editor.viewModel.sketchViewModel.defaultCreateOptions.preserveAspectRatio = false;
achyl
It didn't work,
I set this property in editor.when(), but when I create a new object, this property is overwritten
Jan62
<html lang="en">
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/WebMap",
        WebMap, MapView,
        Editor
          portalItem: {
          map: webmap
        view.when(() => {
            view: view,
  </script>
</head>
<body>
</body>
</html>
<html lang="en">
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/WebMap",
        WebMap, MapView,
        Editor
          portalItem: {
          map: webmap
        view.when(() => {
            view: view,
  </script>
</head>
<body>
</body>
</html>
achyl
Thank you,
after downgrading version it works, but only for 2D objects, I can't lock the scaling of a point-3d type symbol.
Jan62
Update:
with 4.30 now it works to override the behavior. Look at SupportingWidgetDefaults Editor | API Reference | ArcGIS Maps SDK for JavaScript 4.30 | Esri Developer
The example disables the scaling and rotation on update.
<html lang="en">
<head>
  <title>Edit features with the Editor widget | Sample | ArcGIS Maps SDK for JavaScript 4.30</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.30/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.30/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/WebMap",
        WebMap, MapView,
        Editor
          portalItem: {
          map: webmap
        view.when(() => {
            view: view,
            supportingWidgetDefaults:{
              sketch:{
                defaultUpdateOptions:{
                  enableRotation: false,
                  enableScaling: false
  </script>
</head>
<body>
</body>
</html>
