This example
https://developers.arcgis.com/javascript/latest/sample-code/widgets-print/
In the layer, some layers are hidden in the list,
When Output PDF still display,
Can control the legend Individual display?
Hi @Wade, are you talking about hidden layers displaying in the printed legend? If so, this is a known issue that was recently fixed. You can see the fix now using next, or wait for 4.22 to release (which should be later this week).
next: https://github.com/Esri/feedback-js-api-next
@Wade By default Print widget in JS API honors only the visible layers. I tested the sample and it is working fine. please check the screenshots Sandbox app with displaying he legends:
and the print generated from the app:
If you can provide more details on the requirements we can check.
Hi @Kishore
The question is, There are two layer inside, One does not display in the list,
When Output PDF still display, Can control the legend Individual display?
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>Print widget | Sample | ArcGIS API for JavaScript 4.21</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.21/esri/themes/light/main.css" />
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
.esri-zoom {
display: none;
</style>
<script src="https://js.arcgis.com/4.21/"></script>
<script>
require([
"esri/views/MapView",
"esri/Map",
"esri/layers/FeatureLayer",
"esri/layers/MapImageLayer",
"esri/widgets/LayerList",
"esri/widgets/Print",
MapView,
Map,
FeatureLayer,
MapImageLayer,
LayerList,
Print
const map = new Map({
basemap: "topo-vector"
const view = new MapView({
container: "viewDiv",
map: map,
extent: {
xmin: -9177811,
ymin: 4247000,
xmax: -9176791,
ymax: 4247784,
spatialReference: 102100
const featureLayer = new FeatureLayer({
url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Landscape_Trees/FeatureServer/0",
listMode: "hide"
const mapImageLayer = new MapImageLayer({
url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer"
map.add(featureLayer);
map.add(mapImageLayer);
view.when(() => {
const print = new Print({
view: view,
printServiceUrl:
"https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
const layerList = new LayerList({
view: view
view.ui.add(print, "top-right");
view.ui.add(layerList, "top-left");
</script>
</head>
<body class="calcite">
<div id="viewDiv"></div>
</body>
</html>
Hi @Noah-Sager
Thank you for providing information.
@Wade, quite welcome. Feel free to mark my post as the solution if you feel it answered your question.
