Create an API key
2195
07-22-2024 11:10 AM
ForrestLin
I'm following the tutorial to create an API key:
https://developers.arcgis.com/documentation/security-and-authentication/api-key-authentication/tutor...
I login to my Portal using admin account, but I can't find button "New item" in  Content > My content
There are button "Add Item" and "Create", but there is no Developer credentials > API key credentials
Regards,
Forrest
mnoel2
If you are using a AGOL for personal use, we are no longer able to generate an API key from that AGOL account. You need sign to developers.arcgis.com account, and select ArcGIS Location Platform, also you may need to create another AGOL account public that is, may need to use another e-mail to associate with that. That is the work around I got from Esri support. Good Luck!
mnoel2
