COG ImageryTileLayer in SceneView doesn't load higher LOD when zoomed in
5786
12-02-2022 01:56 AM
TumasGuogis
As the title says, the layer only shows a very low level-of-detail when in SceneView, even when zoomed in close.
MapView vs SceneView:
Can be replicated by changing MapView to SceneView in this sample:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=layers-imagerytilelayer-...
UndralBatsukh
Hi there,
This appears to be a legit issue for ImageryTileLayer in SceneView. Thank you for reporting this issue and I will update you once we have a fix for this.
-Undral
UndralBatsukh
Hi there,
This bug will be fixed in JS API version 4.28 which will be released late Oct 2023. You can test the fix in our next release after Sept 19th. Please check the changelog for the fix: https://github.com/Esri/feedback-js-api-next/blob/main/CHANGELOG.md
