Click table row and map goes to feature location
1043
08-28-2019 10:35 PM
kawishabbas
Hi
i have some records of related table.I want to add click event on row that when clicked on table row map should go to feature location. Please consider the following snippet of code in which click event is working only for first click if i click second time to same row or any other row it does not working.
Robert Scheitlin, GISP‌ Egge-Jan PolléKelly Hutchins
Response from related record
array of relatedRecordGroups
 let fatdiv = document.getElementById('fat')
                        fatdiv.addEventListener('click', () =>{
                            queryRelated({
                                url: "https://172.16.6.159:6443/arcgis/rest/services/KarachiSDE/FeatureServer/1",
                                objectIds: _this.state.id,
                                relationshipId: 1,
                                returnGeometry: true,
                                outFields: ["Name", "FAT", "DC", "POP"]
                                /*  params: { returnCountOnly: true } */
                                .then(response => {
                                    console.log(response)
                                    myTableDiv.innerHTML = ''
                                    var table = document.createElement('TABLE');
                                    table.setAttribute('id', 'table')
                                    //table.appendChild(close)
                                    var thead = document.createElement('thead')
                                    table.appendChild(thead)
                                    var header = document.createElement("tr");
                                    header.setAttribute('id', 'header-tr')
                                    thead.appendChild(header)
                                    var tbody = document.createElement('tbody')
                                    table.appendChild(tbody)
                                    if (response.fields) {
                                        response.fields.forEach(j => {
                                            var column = document.createElement("th");
                                            column.setAttribute('id', 'table-header')
                                            column.textContent = j.alias;
                                            header.appendChild(column);
                                            // console.log(j)
                                    else {
                                        return null
                                    response.relatedRecordGroups.forEach(e => {
                                        e.relatedRecords.forEach(i => {
                                            console.log(i)
                                            var row = document.createElement("tr");
                                            tbody.appendChild(row);
                                            response.fields.forEach(k => {
                                                //console.log(response.fields)
                                                var columns = document.createElement("td");
                                                columns.textContent = i.attributes[k.name];
                                                row.appendChild(columns);
                                                columns.addEventListener('click', () => {
                                                    //console.log(i.geometry)
                                                    view.goTo({
                                                        target: [i.geometry],
                                                        zoom: 18
                                            /*       console.log(i.attributes.Name)
                                                 console.log(i.attributes.FAT)
                                                 console.log(i.attributes.DC)
                                                 console.log(i.attributes.POP)  */
                                    }) //console.log(response.relatedRecordGroups)
                                    myTableDiv.appendChild(table);
                                    //view.ui.add(expand, 'top-left')
Tags (1)
