changing token duration
1208
09-03-2022 04:18 AM
Mannus_Etten
i set those properties in my oauthinfo-object:
    expiration: 200,
    minTimeUntilExpiration: 180,
i can see in the console log that those settings are set but when i obtain an token and check
credential.expires the timestamp is still only 30 minutes valid.
I would like to make this period longer or it would be nice if i can obtain the refreshtoken
from the oauthinfo-object.
In that case my backend can renew the access token.
Portal Genius / KLIC Genius / Backup Genius
JeffreyWilkerson
Here's a call using jQuery with an object that has the expiration set to 200, and the resulting token says that it's valid for '12000':
var form = new FormData();
var settings = {
  "url": "https://www.arcgis.com/sharing/rest/oauth2/token?client_id=xxx&client_secret=xxx&grant_type=client_credentials&expiration=200",
  "method": "POST",
  "timeout": 0,
  "processData": false,
  "mimeType": "multipart/form-data",
  "contentType": false,
  "data": form
$.ajax(settings).done(function (response) {
  console.log(response);
Resulting token:
    "access_token": "xxx..",
    "expires_in": 12000
Client, client secret, and resulting tokens were obfuscated to protect the innocent...
