changing info in pop-up
962
11-17-2023 01:39 AM
JLM
Hi experts,
is it possible to change the info in the pop-up? It would be nice if there is a little more info and not the same title. So it's easier to know which one to select.
thanks in advance,
Lee
Tags (1)
KenBuja
MVP Esteemed Contributor
Yes, you can add additional information to the title property of the template. For example
const template = {
  title: "Earthquake Info for {place}",
  content: "Magnitude {mag} {type} hit {place} on {time}",
  fieldInfos: [
      fieldName: "time",
      format: {
        dateFormat: "short-date-short-time"
will give you this result
