cannot select basemap in Basemap gallery
809
10-13-2022 05:31 AM
ADITYAKUMAR1
  I am using ArcGIS JavaScript 4 and I have added base map gallery widget to my application. I had my own container which I added to the gallery. But after adding the widget I am not able to select any layer inside the widget.
I followed the ESRI example to add a widget and there also same problem exist.
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-expand
Is this a problem from ESRI side? Has anyone else encountered this problem?
Aditya Kumar
