'Cannot locate when disabled.'
1840
03-23-2023 02:28 AM
Blakearc
I am using ArcGIS with react. I have successfully displayed a map and now I want to get current location once the map is loaded. I included all the setup inside a useEffect hook. I configured the location widget as below:
const locateWidget = new ArcGISLocate({
    view: view,
    useHeadingEnabled: false,
    goToOverride: function (view, options) {
        options.target.scale = 1500;
        return view.goTo(options.target);
locateWidget.locate().then(function () {
    console.log("success");
However I got the following error return:
    details: undefined
    message: "Cannot locate when disabled."
I tried using HTTPS over HTTP but the error still exists. How to solve this problem?
AndyGup
Hi @Blakearc most likely the View isn't ready (view.ready === false) when you try to initialize the Locate widget. If you are still having issues after looking into that, you'll need to provide a focused, working github repo, stackblitz or codesandbox example of your React project. Here a basic troubleshooting guide: https://github.com/Esri/jsapi-resources/blob/main/TROUBLESHOOTING.md#four-triage-steps.
AndyGup
Blakearc
Thank you for answering. I put the locate() into view.when() and it works now !
