Can't customize LayerList styles in JavaScript Maps SDK 4.29
3003
8
03-14-2024 03:17 AM
AnastasiiaDzundza
With JavaScript Maps SDK 4.28 we customized a bit styling LayerList on our website to be consistent with our project's design. For example visibility icon was changed to checkbox. But since 4.29 our style overwriting doesn't apply anymore.
Reaching layerList elements isn't accessible any more since calcite  elements are used to shape the widget and  we can't reach with simple styling the elements inside it.
Does anyone know some approaches how to do it?
Sage_Wall
Hi @AnastasiiaDzundza ,
Thanks for reaching out.  Since we refactored the layer list to use calcite components you will need to follow the colors and theming guide found there.  To add your checkboxes back we added a new property at 4.29 called visibilityApearance that will allow you to switch between the visibility icons and a checkbox.  Hope this helps.
Sage_Wall
AnastasiiaDzundza
Thank @Sage_Wall you a lot for the answer, any chance you can tell me if the is any java script api that alows to change the order of expand/collapse button and custom added actions?
Sage_Wall
There isn't any properties to control the placement of the expand/collapse button and the actions menu outside of the left-to-right and right-to-left settings (https://developers.arcgis.com/javascript/latest/localization/#support-for-right-to-left-rtl).  Custom actions can be easily added using the listItemCreatedFunction and then adding items to the actionsSections .  There is a sample located here: https://developers.arcgis.com/javascript/latest/sample-code/widgets-layerlist-actions/
AnastasiiaDzundza
But is there any way to re define expand/collapse button in actions list? Under listItemCreatedFunction?
Sage_Wall
There is no current way in the LayerList API to modify the expand and collapse button to show/hide a layer's sublayers outside of the calcite colors and theming guide.  https://developers.arcgis.com/calcite-design-system/foundations/colors/#:~:text=Calcite's%20default%....
AnastasiiaDzundza
Got it, appreciate your reply.
Sage_Wall
Happy to help, if you could change the expand buttons, how would you?  Always looking for ideas on how to make things better. Maybe it's something we could consider in a future release.
AnastasiiaDzundza
Well, last my question was triggered  by the need to have a trash icon before expand/collapse button in one line. Checkboxes that handle layer visibility we keep in front of layer title.
