Can definitionExpression be dynamically used with zoom scale/LOD ?
1443
09-01-2020 09:32 AM
victhomas
Hello,
Just a quick question in regards to layer's definitionExpression, have been searching for a little bit but haven't come across it.  Is there a way to display how many features gets to be rendered based on the zoom scale or LOD?  example; set definitionExpression = 'active' at the start of the map load 1:1,000,000, as users zoom in further to 1:500,000 definitionExpression in ('inactive','active'), and so on so forth.  TIA.!
RobertScheitlin__GISP
Vic,
   If you are asking about 4.x then just add a watch on the views scale property and change the layers def expr based on that.
TanuHoque
Vic,
Not sure whether you question was more from programing side or not. If the Q was about programming side, then you can skip the rest of my comment.
Otherwise, if you publish your data from ArcGIS Pro and as a map service (aka map image layer), you can use display filters - as the name suggests, unlike def queries this only affects drawing, but if you want to query/identify you can still do that on features that are not drawn
Use display filters—ArcGIS Pro | Documentation
please let me know if you have any question.
Thanks.
Tanu
