<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9"> <title>mapMUSKEGO | mapVEPRASKAS</title> <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.10.2/jquery.min.js"></script> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <style type="text/css"> html,body,#map{ padding:0; margin:0; overflow:hidden; height:100%; background-color:#dbddda; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> dojo.require("esri.map"); var map; var initExtent; var buttonclick; function init() { initExtent = new esri.geometry.Extent(2485078.859947771, 312461.2599477768, 2517629.6100261062, 344895.2419843375, new esri.SpatialReference({ "wkid": 32054 })); map = new esri.Map("map", { extent: initExtent, logo: false, slider: false}); var greyMAP = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer", { }); map.addLayer(greyMAP); } function buttoncall() { buttonclick = dojo.connect(map, "onClick", resultFunction); } function resultFunction() { dojo.disconnect(buttonclick); alert("test"); } dojo.ready(init); </script> </head> <body> <div id="map"></div> <a href="javascript:buttoncall()" id="button1" ><img alt="button1IMG" id="button1IMG" style="bottom:10px; left: 10px; width:36px; position:absolute; z-index:22; border:none;" src="images/Button.png"/></a> </body> </html>
This should work for either one...Create a global variablevar buttonclick;Then create the function the button calls function buttoncall() { buttonclick = dojo.connect(map, "onClick" resultFunction); } function resultFunction() { dojo.disconnect(buttonclick); alert("test"); }Give it a shot
var buttonclick;
var buttonclick; function buttoncall() { buttonclick = dojo.connect(map, "onClick" resultFunction); } function resultFunction() { dojo.disconnect(buttonclick); alert("test"); }
Hi Jay,Here is an example that sets the infoTemplate each time the button is clicked.
<input type="button" id="button" value="Identify" />
on(dom.byId("button"), "click", function () { featureLayer.setInfoTemplate(template); initializeSidebar(app.map); on(app.map.infoWindow, "show", function () { featureLayer.setInfoTemplate(null); }) }) function initializeSidebar(map){ var popup = map.infoWindow; //when the selection changes update the side panel to display the popup info for the //currently selected feature. connect.connect(popup, "onSelectionChange", function(){ displayPopupContent(popup.getSelectedFeature()); }); //when the selection is cleared remove the popup content from the side panel. connect.connect(popup, "onClearFeatures", function(){ //dom.byId replaces dojo.byId dom.byId("featureCount").innerHTML = "Click to select feature(s)"; //registry.byId replaces dijit.byId registry.byId("leftPane").set("content", ""); domUtils.hide(dom.byId("pager")); }); //When features are associated with the map's info window update the sidebar with the new content. connect.connect(popup, "onSetFeatures", function(){ displayPopupContent(popup.getSelectedFeature()); dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected"; //enable navigation if more than one feature is selected popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager")); }); } function displayPopupContent(feature){ if(feature){ var content = feature.getContent(); registry.byId("leftPane").set("content", content); } }
require([ ], function( ) {
