bootstrap-map - popups?
3701
05-06-2015 06:47 AM
TracySchloss
Honored Contributor
I am attempting to make my maps more responsive using bootstrap-map and dojo-bootstrap.  I typically use a popup for my infoWindow, defined as
var highlightMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 22,
    new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
    new Color([255,255,0]), 2),new Color([255,255,0,0.4]));
  var popup = new Popup({
    markerSymbol: highlightMarkerSymbol},
    domConstruct.create("div"));
   map = new Map("mapDiv", {
    infoWindow: popup,
    basemap: "streets",
    center: [-92.593, 38.5],
    zoom: 7
Using bootstrap-map instead as
var map = new BootstrapMap("mapDiv", {
    infoWindow: popup,
    basemap: "streets",
    zoom: 7
I'm not getting an error creating a bootstrap map including a popup parameters, but I'm not seeing the typical 'Zoom to' link at the bottom of my infoWindow either. Is this just a styling issue? That was part of the functionality that I liked for using popups.  I can see why you might want to have a scaled down infoWindow for a small device, but for a desktop size, it seems like you'd still want to have the full functionality I'm used to seeing.
Am I missing something?  Where do I find documentation that gives more detail on the difference between map vs. bootstrap-map?  I'm not see much on github.
