I want the map extent to change by clicking on some text. I'm using the example Add Dynamic Map and I have added the following codefunction myzoom() {
var axtent = new esri.geometry.Extent(55.6153456, 5.7191691, 105.6673614, 37.0016790, map.SpatialReference);
map.setExtent(axtent);
}I have tried placing it both outside of the init function and inside the init function. In both cases I get an error when I call it <p id="test" onClick="myZoom();">click for zoom</p>
If I add an alert function outside of the init function
function nTest(){
alert("test2");
}and call it from here <p id="test2" onClick="nTest();">click for alert</p>
it works.Why?- Mike
