ArcGis corrupts URLs
3558
11
07-29-2022 03:25 AM
TimDietz
Is there a way you can start with a partial URL and then programmatically set the color_formula?
Karrok
What do you mean by "start with partial"? Did you try to open the correct link with and without color_formula?
If it's possible to apply the coloring setting "on the fly" somewhere in fetchTile, please show me how to do it.
Also, I assume that applying such changes for each tile will have poor performance
TimDietz
Yes.  Try https://planetarycomputer.microsoft.com/api/data/v1/mosaic/tiles/7557a0b9c1e010154c6c34b5616ce374/We...
I do not work with this API so I can't show you.  I am just throwing out possibilities.  You might have to get the help from someone who does know this API.
Karrok
As for me with and without color_formula tile looks totally different.
The question is why arcgis request performs url encoding, I need to skip it, try to run a simple plain JS -
var httpRequest = new XMLHttpRequest();
httpRequest.open('GET', 'https://planetarycomputer.microsoft.com/api/data/v1/mosaic/tiles/7557a0b9c1e010154c6c34b5616ce374/WebMercatorQuad/10/174/[email protected]?pixel_selection=first&assets=red&assets=green&assets=blue&collection=landsat-c2-l2&color_formula=gamma+RGB+2.7%2C+saturation+1.5%2C+sigmoidal+RGB+15+0.55');
httpRequest.send();
correct tile will be loaded, no errors, no url encoding
TimDietz
From https://doc.arcgis.com/en/arcgis-online/reference/use-url-parameters.htm
"All query parameters must be encoded. URL encoding ensures that valid characters are sent to ArcGIS Online. Encoding replaces invalid characters with % followed by their hex equivalent."
Karrok
ok, but I'm sending a request not to "ArcGIS Online", right?
TimDietz
Yes, and that's why I said you might have to get the help from someone who does know this API.
JohnGrayson
Esri Alum
I believe the issue is that the color_formula you're trying to use is already encoded.  Using decodeURIComponents produces the following parameter:
gamma+RGB+2.7,+saturation+1.5,+sigmoidal+RGB+15+0.55
As shown in the previous example I would recommend you try to configure the base part of the url (before the ? char) and all the parameters separately so you have better control of the URL being requested.
JohnGrayson
Esri Alum
...but that doesn't quite give us the final solution as those parameters still have undesired encoding of the '+' sign for spaces.  Here's a code pen showing how to configure the parameters correctly:
https://codepen.io/john-grayson/pen/ExEozep
