import { Component, Inject, OnInit, CUSTOM_ELEMENTS_SCHEMA } from '@angular/core';
import { CommonModule, DOCUMENT } from '@angular/common';
import IdentityManager from "@arcgis/core/identity/IdentityManager";
import ServerInfo from "@arcgis/core/identity/ServerInfo";
@Component({
selector: 'app-home',
standalone: true,
imports: [ CommonModule ],
providers: [ ],
templateUrl: './home.component.html',
styleUrl: './home.component.scss',
schemas: [CUSTOM_ELEMENTS_SCHEMA]
export class HomeComponent implements OnInit {
constructor() { }
ngOnInit(): void {
var si = new ServerInfo({
hasPortal: true,
server: 'http://myportal.mydomain.com/arcgis',
IdentityManager.registerServers([si]);
IdentityManager.getCredential(environment.portalUrl);
IdentityManager.checkSignInStatus(si.server + "/sharing")
.then(() => {
console.log("checkSignInStatus: User is signed in.");
.catch(() => {
console.error("checkSignInStatus: User not signed in.")
}I'm developping an Angular 19 app using @ArcGIS/core && @ArcGIS/map-components and thing are going well. Only thing left to do is the portal authentication (get a token).
Is there a sample somewhere to help me. I find stuff here and there some with deprecated stuff, some in pure JS but I want to do it cleanly with Angular.
I have tried this but I get this erreor after the build:
Error when evaluating SSR module.. ReferenceError: ResizeObserver is not defined
Can you help with a sample please?
@Component({
standalone: true,
providers: [ ],
constructor() { }
ngOnInit(): void {
hasPortal: true,
.then(() => {
.catch(() => {
