Add Google Basemap via Javascript
22417
15
01-18-2014 08:38 AM
deleted-user-XuRyPg9pv1OY
I am new to writing code and need help displaying a Google basemap (hybrid) in a web map built on the ArcGIS Javascript API. I have a Google Maps API key, which was removed for this example. I used the documentation at http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.00/docs/googlemapslayer/examples.html as a guide, but I am stuck. Any help would be greatly appreciated!
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title></title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css" />
    <link rel="stylesheet" href="css/layout.css"/>
    <script>
    var djConfig = {
              parseOnLoad: true,
              packages: [{
                "name": "agsjs",
                "location": 'https://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.04/xbuild/agsjs' // for xdomain load
   </script>
    <script src="http://maps.google.com/maps?file=api&amp;v=3&amp;key=" type="text/javascript"></script>
    <script src="http://js.arcgis.com/3.8/"></script>
    <script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
   dojo.require("agsjs.layers.GoogleMapsLayer");
      dojo.require("dijit.layout.TabContainer");
      dojo.require("esri.dijit.Legend");
      var map, googleLayer;
      function init() {
        map = new esri.Map("map", {
          center: [-82.65862, 29.820309],
          zoom: 16
        googleLayer = new agsjs.layers.GoogleMapsLayer({
                apiOptions: {
                  v: '3'
        map.addLayer(googleLayer);
      dojo.ready(init);
  </script>
  </head>
  <body class="claro">
    <div id="mainWindow"
         data-dojo-type="dijit.layout.BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%; height:100%;">
      <div id="header"
           data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
        Tool
      </div>
      <div data-dojo-type="dijit.layout.ContentPane" id="leftPane" data-dojo-props="region:'left'">
        <div data-dojo-type="dijit.layout.TabContainer">
          <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend', selected:true">
            <div id="legendDiv"></div>
          </div>
          <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Identified Issues'" ></div>
      </div>
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
      <div id="footer" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'"></div>
    </div>
  </body>
</html>
Thank you!
Matt
LefterisKoumis
Thank you. However, it seems that the use of the above urls for the google maps violate the terms of use with Google. For the users who have a license how do they specify their license key or clientID?
ChristopherSchreiber
Is this allowed with Google Maps TOS? I have read before that Google does not allow it's maps to be used in any application that is based off of another mapping API (Like Esri).
Chris
RobertScheitlin__GISP
Christopher,
   You are correct this is a violation of the TOS.
LefterisKoumis
It is not clear in the Google TOS that it is a violation to use Google Map on another API, if you possess a license.
Lefteris,
Here is the entry that I am referencing:
  1. No use of Content with a non-Google map. You must not use the Content in a Maps API Implementation that contains a non-Google map.
This is Requirement 10.4.e.
Link: Google Maps APIs Terms of Service  |  Google Maps APIs  |  Google Developers
I am not sure how licensing works with this though, I would contact a Google rep just to be sure.
Chris
LefterisKoumis
Thanks. I believe that when you purchase a license there is no condition that the license can be used only on Google API based products. Unless it is explicitly stated otherwise, when you purchase a license for a software you are free to use it (not modify) as you wish.
