Access polygon features with pointer events
3453
10
04-02-2024 01:53 PM
ArianaToth
Hi, I'm trying to modify the Access features with pointer events sample code from the ArcGIS Developers site. I want it to work with an existing webmap and with a polygon layer instead of a line. I've run the code through ChapGPT, which had me make some changes from the original structure, but the code isn't working either way. (Feature layer url and portal item id have been removed from the code below, but both do load in codepen.)
Any help would be much appreciated.
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>Access features with pointer events | RH Planning Areas</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #info {
        background-color: black;
        opacity: 0.75;
        color: lightBlue;
        font-size: 18pt;
        padding: 8px;
        visibility: hidden;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.29/"></script>
    <script>
      require(["esri/WebMap", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/symbols/SimpleFillSymbol"],
      (WebMap, MapView, FeatureLayer, SimpleFillSymbol) => {
        const PlanningAreasLayer = new FeatureLayer({
          url: "https://.../FeatureServer/0",
          outFields: ["*"]
        const webmap = new WebMap({
          portalItem: {
            portal: "https://www.arcgis.com",
            layers: [PlanningAreasLayer]
        const view = new MapView({
          container: "viewDiv",
          map: webmap,
          center: [-83.1563078,42.6645259],
          zoom: 12,
          highlightOptions: {
            color: "lightBlue"
        view.ui.add("info", "top-right");
        view
          .when()
          .then(() => {
            return PlanningAreasLayer.when();
          .then((layer) => {
            const renderer = layer.renderer.clone();
            const fillSymbol = {
              type: "simple-fill",
              color: [255, 0, 255, 0], //transparent fill
              outline: {
                color: [255, 0, 0, 0], //red
                width: 4
          renderer.symbol = fillSymbol;
          layer.renderer = renderer;
            // Set up an event handler for pointer-down (mobile)
            // and pointer-move events (mouse)
            // and retrieve the screen x, y coordinates
            return view.whenLayerView(layer);
          .then((layerView) => {
            view.on("pointer-move", eventHandler);
            view.on("pointer-down", eventHandler);
            function eventHandler(event) {
              // only include graphics from PlanningAreasLayer in the hitTest
              const opts = {
                include: PlanningAreasLayer
              // the hitTest() checks to see if any graphics from the PlanningAreasLayer
              // intersect the x, y coordinates of the pointer
              view.hitTest(event, opts).then(getGraphics);
            let highlight, currentName;
            function getGraphics(response) {
              // the topmost graphic from the PlanningAreasLayer
              // and display select attribute values from the
              // graphic to the user
              if (response.results.length) {
                const graphic = response.results[0].graphic;
                const attributes = graphic.attributes;
                const areaName = attributes.Neighbor_1;
                const mapLink = attributes.Neighborho
                const id = attributes.OBJECTID;
                if (highlight && currentName !== areaName) {
                  //Check if a highlight exists (is not null or undefined)
                  //Checks if the current name is not equal to the name
                  //If true, name has changed so highlight should be removed
                  //If condition is true, execute the following code
                  highlight.remove(); //Remove the highlight from the graphic
                  highlight = null; //Set the highlight variable to null
                  return; //Exit the current function
                if (highlight) {
                  const query = layerView.createQuery();
                  query.where = "NAME = '" + areaName + "'";
                  layerView.queryObjectIds(query).then((ids) => {
                    if (highlight) {
                      highlight.remove()
                    highlight = layerView.highlight(ids);
                    currentName = areaName;
                //diplay information about the feature
                document.getElementById("info").style.visibility = "visible";
                document.getElementById("name").innerHTML = areaName;
                document.getElementById("link").innerHTML = mapLink;
              } else {
                // remove the highlight if no features are
                // returned from the hitTest
                if (highlight){
                  highlight.remove();
                  highlight = null;
                document.getElementById("info").style.visibility = "hidden";
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <div id="info">
      <span id="name"></span> <br />
      <span id="link"></span>
    </div>
  </body>
</html>
--Ariana
UndralBatsukh
You have to update the field names for the query in your app. You are using wrong field names. For example, your service does not have a field called areaName. In any case, I updated the same codepen to reflect these changes. Please create a new question if you need further help on this.
