4.3 how does map/api determine whether or not to redraw a layer
718
06-12-2017 08:42 AM
deleted-user-6W3sI5mzODmY
I'm having an issue of a layer not clearing its graphics after calling removeAll if I'm also adding a new graphic in the same call.  It will clear fine if I'm not adding a new graphic.
I've had other issues where I am changing a property in the graphic but the map does not redraw the graphic.  I can work around this issue by creating a new instance of the graphic and copying over the properties.
Is there a way to manually redraw a layer?
