4.29.6 - OGC Feature Layer not rendering full view
1199
03-12-2024 12:01 PM
KarenAnjosArcoverde
Hello. I'm trying to put a large amount of data into OGCFeatureLayer and using CIMSymbol to draw the points. As I zoom out, some points disappear, if I zoom in they reappear. I think it's a bug in the OGC Feature Layer or a limit on the amount of data. Would it be possible to fix this problem or change this limit? Thanks!
AnneFitz
Hello, sorry to hear that you're running into this issue! Are you using version 4.29 of the API? If you change it back to 4.28, is the issue still reproducible?
Could you create a codepen or some sort of reproducible code snippet? This would help us debug the issue. Thanks!
