4.27 - Popup location issue
1395
06-29-2023 01:08 AM
michaelpoa
Popup will not update / trigger change detection when async data is loaded.
Reproduce:
https://codepen.io/michaelk95/pen/eYQvReQ?editors=1100
Initial popup state:
When data is loaded (async)
 The width of the popup should be auto (fit-content)
.esri-popup__main-container {
    width: auto !important;
It's only with version 4.27. The popup DOM element should be updated when the popup.content has changed. Can someone have a look? Thanks
ReneRubalcava
Esri Frequent Contributor
This works if you remove the custom css you added to modify the popup. You might need to adjust that.
michaelpoa
Yes, correct
But it's not possible to set the popup's width to auto?
For example:
esri css:
.esri-view-width-large .esri-popup__main-container {
    width:400px;
But I don't want the popup to have a fixed size, it should fit the content? Not possible?
THanks
ReneRubalcava
Not for the popup. If you need something slightly different, you might want to look at the Features widget which lets you place popup content anywhere you want.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Features.html
