Zone Lookup Push Pins
2138
13
07-01-2024 08:17 AM
SavannahThomson1
Is there a way for the map pin to go to the address that is entered rather than the middle of the zone it is within? Our workaround was to only have the address label appear because the pin is confusing.
It would be amazing to have the pin show up on the address entered so the end user could see where they are within the zone!
The image below shows the push pin going to the center of the zone rather than the address (circled in red).
816am
I am still having this issue, was a fix ever implemented? Picking the location works fine, but entering an address caused the pin to be placed at the zone center. When I turn on the address label for the pin it behaves exactly as the original issue. The strange part was everything was functioning as expected, until I published the app. Then this behavior started.
SavannahThomson1
The update Kelly mentioned fixed mine. Hopefully she has a solution for you as well!
KellyHutchins
Esri Notable Contributor
Are you using Enterprise or Online? If Enterprise which version? And are you using the default locator or do you have a custom one? Is your app public? If so can you share the url so I can take a look?
816am
We are AGOL for this app using a Springfield Locator that is in my portal. I do have the default ArcGIS locator in the app as well and tested using that locator. Same result. We are in testing phase for the app, but I just published with public access here:
https://subh2o.maps.arcgis.com/apps/instant/lookup/index.html?appid=670b1f2c85c0422c9ffd28f97781e795
Thank you Kelly!
