Zone Lookup Push Pins
2241
13
07-01-2024 08:17 AM
SavannahThomson1
Is there a way for the map pin to go to the address that is entered rather than the middle of the zone it is within? Our workaround was to only have the address label appear because the pin is confusing.
It would be amazing to have the pin show up on the address entered so the end user could see where they are within the zone!
The image below shows the push pin going to the center of the zone rather than the address (circled in red).
KellyHutchins
Esri Notable Contributor
Looks like this happens in cases where there is a search layer defined and an address is entered in the search box. We have a fix for this and it will get pushed to ArcGIS Online one night this week.
PaulCone2
SavannahThomson1
Yes! How did you do that? The only way I could get the pin on an address in my app was manually clicking.
PaulCone2
I'm not sure since it's been a while since I set this up, but here's the settings...
SavannahThomson1
I used "features within zone" since this is a school locator app but unfortunately the "for a zone" option did not fix my push pin issue either.
Thanks for trying to help! Hopefully it is an easy fix I am missing.
KellyHutchins
@SavannahThomson1 is your app public if so can you share the link? If not can you provide a screen shot of the settings and I'll take a look.
SavannahThomson1
Here is the link: https://experience.arcgis.com/experience/849bf9b6ea13414889763a075266d5f5/page/Find-Your-Elementary-...
I removed the push pins and only have the address labeled to not confuse people but you can see the address goes to the middle of whatever zone it is in.
These are my current settings (I tried the "for a zone" as well and it did the same thing):
KellyHutchins
Thanks I'll take a look and see what we can figure out.
KellyHutchins
SavannahThomson1
Thank you so much!
