Zone Lookup - Export - Related Table Records Don't Export
353
06-06-2025 06:02 AM
JAbbott
When exporting in zone lookup, the app only exports the geography, not the related records of the geography.
When using the 'Export to CSV' option, it will just give a list of the geography, when using the 'Export' option, the PDF/Image only exports the categories, but no actual data inside of it.
Not sure if there's something I can tweak or if it's just a known issue.
KellyHutchins
Esri Notable Contributor
There are known issues with the export of related records but other records should export as expected.
KellyHutchins
Is your app public so we can test or do you have screen shots that show what you mean by "just give a list of geography"?
JAbbott
Thanks for the reply and I apologize for just getting back to you (shows the last time I logged in here).
But I ended up putting in a support ticket and found some limitations of the app (03922945).
I was hoping that I could get the related table's data to export in the CSV - however it'll only export the underlying geographies.
It's not a huge deal at this point (I disabled the CSV export) but if you'd like to see what I'm talking about I've made the application public and added the csv export option.
https://cuyahoga.maps.arcgis.com/apps/instant/lookup/index.html?appid=7011aaf7292d4ceab90f703d924777...
Thanks again.
