Weather widget in 3D viewer Startup configuration
1811
03-31-2022 08:05 AM
DirkSilbermann
I just tested the weather widget in instant apps and it works nicely so far - we waited for this
One issue is confusing: by default it always starts using "foggy" environment, no matter what is choosen during app configuration (first time I was wondering were the "white overlay" came from).
Please either set start up to "sunny" by default or make it possible to save weather settings during app configuration!
Or do I miss something?
KellyHutchins
Esri Notable Contributor
Good catch on the fog I can see how that would be confusing when the app loads. I will make the update to set sunny as the default weather you should see that update tomorrow.
We also plan to expose the weather type and cloud/fog strength as configurable options at the next release of online due out later this year.
KellyHutchins
DirkSilbermann
Great, thanks for the quick response!
(However, I cant see any changes if app loads until now, hope you can give us sunny weather by default, soon 😉
KellyHutchins
@DirkSilbermann  there was a delay in the update - the current plan is for it to go live tonight. In the meantime if you need a fix and are familiar with using AGO Assistant you can edit the app data and change the weatherType property from foggy to sunny.
Stefan_Thorn
@KellyHutchins at this moment it is only possible to use the weather widget in a global scene. Will it also become usable in a local scene?
KellyHutchins
We rely on the widget from the ArcGIS Maps for SDK and currently that widget does not support local scenes: https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Weather.html
