How to set to true?: 'This application requires a layer that supports attachments and has 'supportsQueryAttachments' set to true'
1628
05-09-2024 09:08 AM
Amarz
Hello,
I am receiving this error when attempting to use the Attachment Viewer Instant App but can't find resources on how to set to true 'supportsQueryAttachments'.
This application requires a layer that supports attachments and has 'supportsQueryAttachments' set to true.
Enterprise 11.2 with ArcPro 3.2.
Data is inside an Enterprise GDB and published as a feature service to Portal.
VHolubec
Hello @Amarz
when you check your Feature Service, has this service Attachment enabled, and please check the QueryAttachment is present in the REST page of the layer in the Feature Service:
Vladimir
Amarz
I do see that as an option, and when I query an attachment, I get the following:
VHolubec
It should work then - could you share the URL of the Serivce @Amarz?
Vladimir
DakotaLott-Werkheiser
Hey Amarz,
I'm still on 11.1 but I'm having the same issue. I've found that if you have published a dataset where only some of the feature layers have attachments that it will throw this error. If you create a new map with only the layers with attachments you should be able to get it to work.
