How do I disable "Don't show this again" on Introduction window
1264
8
05-17-2024 11:58 AM
RyanBohan
How to I disable "Don't show this again" on Introduction window within the Sidebar Instant app
  • The Introduction window contains key information on how to use the app and any limitations
In webapp builder there was options for a Splash Screen
  • "Always show this splash screen every time the app launches"
Zrobinson_SFPUC
Did you ever figure out a way to disable that? We also need the information window to show every time the map loads.
RyanBohan
Not yet, I asked about it at the Esri UC 2024.  Hopefully, it will be an option soon.
KellyHutchins
Esri Notable Contributor
In the next release of ArcGIS Online if the app you are using supports a Custom CSS option in the configuration experience you will be able to hide this button using the following css
instant-apps-splash {
  --instant-apps-splash-back-content-display: none;
 We will add this as a configuration option in a future release.
HenriqueRamos1984
Do you have any idea when it will be available on the enterprise? I have tried there, but it didn't work.
KellyHutchins
Which app are you looking at and which version of Enterprise?
HenriqueRamos1984
I'm using the Enterprise 11.5, and trying to create a Portfolio and a 3D viewer. Both are working well, but we want to take off this check box, so the message will appear every time the user logs in.
HenriqueRamos1984
By the way, I found out the calcite version I have here: 3.2
Kiran_Rupali
Thank you for the update ! This will be very helpful for us and we will end up using more of the instant apps.
-Rupali
