What’s new in Manager (February 2025)
418
02-26-2025 01:51 PM
AzizaParveen1
New features added in Manager Instant App for February 2025 release and few other major enhancements we have added in the past release.
Filter table by map extent: After February update Filter button will always show, when you click on it, Filter modal will open from where you will find an option to turn Filter by map setting.
Select/deselect all fields in one click: We added this support at the configuration level
View and manage attachments from Table: If you have attachments in your features, you should be able to view and manage attachments in table, no configuration needed.
Highlighting support for features in the map: We added highlight support for map features, when you have multiple features selected, all of them will be highlighted in cyan, now if you hover over on selected features rows from the Table, you will see the hovered over features will be highlighted in yellow to give you visual clue. The feature that is showing in the Information panel will be highlighted in magenta.
Map search: If your layer is configured for searching in the web map settings in Map Viewer. You should be able to search your layer for features in the using search button on the map.
Table search: You can also enable search in the table by calculating full text index of the fields that you need to search on. Full text index can be calculated in the feature layer item settings page (Manage Index section). Once you have full text index calculated, you should see search bar in the Table.
Map focused layout: We introduced new map focused layout for creating new feature, table does not show up in this layout so you can have larger map to create new feature. Clicking on Create new feature button defaults to this layout. At runtime you can change the layout that serve your purpose.
Also, we have added a configuration option for layout, so you can choose which layout you want to be your default app layout.
Create new feature and Edit geometry option: We added these two options in the configuration, when enabled you will be able to create new features and Edit geometry. You will find these settings at the individual map level.
