Querying Issue with Map Service Layer in ArcGIS Insights
1421
09-11-2023 11:43 PM
RamaRaomalisetti
Iam currently facing an issue in ArcGIS Insights related to querying a Map Service layer. Despite my best efforts, I'm receiving an error message indicating that the layer does not support querying. I believe the Map Service layer should support querying, and I'm seeking your expertise to help me resolve this problem.
Map Service Properties: I have verified that the Map Service layer I'm trying to query has query capabilities enabled.
Also version is 10.8
Also Support statististics true
Tags (1)
AkshayHarshe
Hi @RamaRaomalisetti
Thanks for your question. Please let me know what operation in ArcGIS Insights is producing this error. Also, send me the steps of your workflow so I understand a little better. What version of ArcGIS Insights are you using? and the URL ends in /mapserver/<#> ?
As far as I know, this should work. I tried this in the current release and it works as expected.
We added the support for the map services at a later point so it is possible you are using an older version of ArcGIS Insights since you are using Enterprise 10.8.
Akshay Harshe
RamaRaomalisetti
Hi  AkshayHarshe
I have added in the portal as item and then i  try to add the item in the insights
AkshayHarshe
@RamaRaomalisetti I am not very sure what other layer properties the layer has or if there was an issue that was fixed at a later point. I would recommend you create a support ticket.
There could be a few other reasons that I can think of that may cause this Check this
https://doc.arcgis.com/en/insights/latest/administer/troubleshoot-map-image-layer.htm
I will also recommend you update to a newer version though you will need to upgrade ArcGIS Enterprise as well. https://doc.arcgis.com/en/insights/latest/administer/enterprise-compatibility.htm
Akshay Harshe
