Insights in Enterprise 11.3?
2312
7
06-03-2024 11:14 AM
AdamRepsher_BentEar
Hi Everyone,
  • I just upgraded to Enterprise 11.3 - and poof - Insights didn't work anymore.
  • I checked that there was not another Insights download.  Nope.  I have the Insights 2023.3 install already.
I now cannot use Insights in Enterprise?
--Adam
AkshayHarshe
@AdamRepsher_BentEar
ArcGIS Insights version 2024.1 will be compatible with Enterprise 11.3 and released in 2-3 weeks. Apologies for any inconvenience. 2024.1 will work with 11.2 and 11.3.
Akshay Harshe
AnthonyRyanEQL
Have you tried to run a repair on the installation of Insights? I wouldn't be surprised settings have been reset, etc that where once written by the insights installation.
I'm interested in how it goes as I'll be doing the same thing in about 6months time. Good luck
AdamRepsher_BentEar
Sorry - I had to uninstall.
The answer is in the next post though.
AkshayHarshe
Akshay Harshe
AdamRepsher_BentEar
Thank you for the information @AkshayHarshe.
Joshua-Young
Honored Contributor
Insights 2024.1 is up on My Esri as of this morning, but I have not seen an annoucement yet.
"Not all those who wander are lost" ~ Tolkien
Joshua-Young
Honored Contributor
Just an FYI, ArcGIS Insights always lags several weeks behind an new releases of ArcGIS Enterprise. At least Esri now has something in the upgrade instructions about verifying app compatibility before upgrading. I just wish Esri would have something in the upgrade instructions that explictly states that if you are using apps x, y, or z do not upgrade ArcGIS Enterprise to the latest version until the new compatible versions of the apps are released, and then update the text once the updated apps are released.
  • If you have Esri apps configured with your portal, ensure you are at a version that's compatible with the 11.3 portal after upgrading.
  • If you configured ArcGIS Insights, you do not need to uninstall it prior to upgrading ArcGIS Enterprise. If you are upgrading both ArcGIS Enterprise and ArcGIS Insights, it is best practice to complete the ArcGIS Enterprise upgrade first, including the post-upgrade steps, before upgrading ArcGIS Insights.
Scott_Tansley
MVP Regular Contributor
Agreed.  I have very few clients with ArcGIS Insights.  It just fell on me that my first 11.3 upgrade was an Insights user and I've been burnt by it - BUT - it's only pre-prod.  I'd raised it as a risk, and had hoped to use the 'latest' release, but it's install validation failed to allow an upgrade.  So we need to wait for the 2024.x release.  Disappointing, but I sort of understand why this happens.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
