Insights Desktop creating incomplete heat/bin maps
815
08-04-2022 10:15 AM
Ed_
by MVP Regular Contributor
I have some point data that I want to use to plot a `heat/bin` map. However, Insights is creating a half `heat map` and a `bin` map with half of the bins grayed out. Please note that the dataset has `236387` observations.
What could be causing this and how can this be fixed?
Point Map in ArcPro:
 Bin Map in Insights Desktop:
Heat Map Insights Desktop:
Question | Analyze | Visualize
KateMaclachlan
Hello,
I'm not certain what is going on here, I'll see if I can reproduce with another dataset.
One thought I had was related to the field being used for the style by.
Are you using a certain field or are you using the location field? In the event you are using a field other than location is it possible there is no data for that field in the lower portion of the map ?
Ed_
Yeah I am beginning to think that I might have made a mistake somewhere in the calculations. I'll check my aggregation process again.
