I have a question regarding link analysis in ArcGIS insights as follows:
I make link analysis using the co-patenting relationships between different cities. I can visualize the link chart using the betweenness centrality to reflect the node size. However, I cannot export the results of betweenness centrality from the Insights. I can only look at the result by clicking on the nodes. I have attached one screenshot for your reference.
May I ask how I can export the calculation results of betweenness centrality from ArcGIS Insights?
Thank you very much for your help!
Thanks for your great question. The link analysis in Insights creates the triple store (from-to-link) dynamically and, currently, we do not save that information anywhere other than in the visual. Currently, there is no ability to export those results. We realize this is a limitation and we have this functionality on a our near-term road map.
Thank you very much for your reply. I look forward to the updated version that contains the funcion of exporting the results.
Best wishes.
Hi Yoga_sweet. If interested, we could have a short conversation to explain how we envision making the centrality results exportable, and more directly usable. It would be great to make sure that our plan meets your needs. Would also love to learn how you are using it. drop me an email (ssandusky@esri.com) to arrange a chat with myself and an Insights team member?
