I'd like to know if it is possible to automaticate the refresh of data in Insights?
Actually, I can only do it manually, if I'm the owner of the Insight page, but not if I'm only a viewer...
I need to have a reporting which is update every day.
Do you know how to do IT ?
Thank you,
Nathalie
It is possible to do this within Insights depending on the version and how your data is sourced.
Happy to walk you through this if you can provide your Insights version and what type of data you have.
Scott
I have this version of Insight:
And I use a Feature web service using data in an Oracle Database (SDE)
Thank you for your help,
Nathalie
Apologies for the delay on this.
In order to maximize performance and interactivity, Insights has a very nuanced approached to dynamic and static data but in your situation I think you're interested in making sure your viewers are seeing the most recent data in your shared page?
If so, you'll want to utilize schedule updates for shared pages. This will ensure that your data is current (given the schedule you setup) on your shared page.
It can be accessed via the share page workflow or on the Pages tab.
