Can users extract data out of Insights for ArcGIS for use in other applications?
2661
12-14-2017 07:32 AM
MatthewKohberger
For example, if I run a spatial aggregation analysis that reports the maximum value for a group of areas, can I extract a table of the results for use in Microsoft Excel, Microsoft Access, or any other statistical software packages?
Thanks!
Matt
AravindStoryMaps
Hi Matthew,
As I'm not sure if you're using Insights for ArcGIS Online or the ArcGIS Enterprise version, I'll add this for everyone who's interested in both the platforms. This can be done in a 2 step process:
1.) You can share your work as datasets in Insights:
Share your data—Sharing in Insights | ArcGIS
Share your work—Insights web help Use tab | ArcGIS Enterprise
In both ArcGIS Online & Enterprise, running spatial aggregation doesn't cost credits.
2.) Once a feature layer item is created in your ArcGIS Online & Enterprise content directory, you can then export your feature layer to a file in order to use it outside of the ArcGIS platform:
Manage hosted feature layers—ArcGIS Online Help | ArcGIS  - You can export a feature layer to (CSV) file, Microsoft Excel file, shapefile, file geodatabase feature class, GeoJSON file, feature collection, or KML.
Manage hosted feature layers—Portal for ArcGIS | ArcGIS Enterprise - You can export to (CSV) file, shapefile, file geodatabase feature class, GeoJSON file, or feature collection at the moment. (Excel file will be available in ArcGIS Enterprise 10.6).
Hope this is what you were asking for!
Aravind
AravindStoryMaps
Hi Matthew,
Aravind
MatthewKohberger
Hi, Aravind.
Yes. This is exactly the answer I was looking for. I am evaluating Insights for ArcGIS through ArcGIS Online.
Thank-you!
Matt
MichaelGinzburg
Can I export Insights reports into Word/PDF/Excel?
Thanks!
