Can't Publish from Desktop version of ArcGIS Insights to Enterprise Portal 10.9.1
1969
7
07-18-2023 02:39 AM
AndrewReynoldsDevon
Can't Publish from Desktop version of ArcGIS Insights to Enterprise Portal 10.9.1.
We have version 2023.1.0.5466 & I've followed the tutorial to create the Ottawa 2 page report on the desktop version which installed & activated ok. I've gone to publish to our enterprise portal as a type 'report' but I get a screen saying ' error - can't publish'.
I can publish to the portal if I choose type model or theme.
Any ideas?
ArchitSrivastava
Hello @AndrewReynoldsDevon ,
A good way to start would be look at the log files present at "%appdata%\Esri\ArcGIS Insights\logs" for ArcGIS Insights Desktop:
This would give us more insights (pun intended) on what could be causing this error. If it's feasible for you share those here, will help in understanding the cause.
Hope it helps!
Archit
AndrewReynoldsDevon
Hi Archit,
Thanks for replying - I've attached the logs as requested.
Andy
Jennifer_Parmeley
I don't have a resolution, but I wanted to share that I had this EXACT problem last month.
I ended up switching development to our portal - due to some internal support issues.
This is an issue and you aren't alone in it. I hope you are able to find a resolution!
ArchitSrivastava
Thanks for sharing the logs. upon investigation I could see few prominent error messages specifically from postgres logs.
It seems interesting that it is receiving command for a shutdown because of updates within few files. I tested a few things at my end was hoping you can share a few files with me.
I will send you the locations via one on one message. I would like to see if those entries are the way it should be. I think it would need more troubleshooting than we expect.
Hope it helps!
Archit
AndrewReynoldsDevon
ok I will share these files via the PM thanks
ArchitSrivastava
Thanks for sharing the files. To understand the full workflow, I wen through the exercise and ran a check. I have noticed some differences but surely not all of them are impacting this process.
I have sent a few suggestions through PM, let's give them a try if possible.
Hope it helps!
Archit
AndrewReynoldsDevon
have replied in PM
