can't export from Data Engineering -- "Something went wrong."
830
7
11-03-2022 09:51 AM
PaulCone2
Occasional Contributor III
I was excited to fire up Data Engineering in ArcGIS Insights Desktop to attempt to wrangle some data from Excel.  It's almost 400,000 records, all the Portland Fire & Rescue incidents for over a year.  I was happy to discover that it could correctly read in the numerous date/time fields, which is more than ArcGIS Pro could do (importing there brought in most of them as text fields).  But then I got the infamous "Something went wrong" error when running the model to export.  How can I get more information about what the error is?  Is there a log file someplace?
Paul Cone
City of Portland, Oregon
Tags (1)
Scott_Aulen
@PaulCone2,
Sorry for the delayed response. Log files can found at these locations:
Windows    C:\Users\<username>\AppData\Roaming\Esri\ArcGIS Insights\logs
Mac    /Users/<username>/Library/Application Support/Esri/ArcGIS Insights/logs
You may need to change your log level to Debug and try the operation again.
PaulCone2
I can't seem to get any sort of problem messages in the log.  Debug didn't show anything so I went all the way to All.
Scott_Aulen
Have you tried with the newly released Insights Desktop 2022.3?
https://www.esri.com/arcgis-blog/products/insights/announcements/whats-new-insights-2022-3/
Several improvements to Data Engineering have been made. If you're still experiencing the issue we can take a closer look.
PaulCone2
Updated to 2022.3, still Something went wrong.  The only fail I see is an http call in the Java log.
MariamMoeen
Hi @PaulCone2,
Would you mind sending me a GIF or exact steps of the workflow that is causing the SWW error to come up on your end? That will help me troubleshoot the issue.
Best,
Mariam
PaulCone2
Hi Mariam,
I have a .xlsx with 394039 rows and columns up to AT (about 175 MB).  It has a lot of date fields.  Here is a snip...
And the import...
Interestingly I tried running this on a different computer before updating and it worked, so I'm assuming it was something with the local install.  And I just tried it in a new workbook and it works.  So I'm guessing there was some crud left over from the previous attempt, which was done under the previous version.  Also I see there are two additional tables to import for metadata and data dictionary.  So thank you for the improvements and I'll let you know if I get stuck again.
Paul
PaulCone2
Ah I have not -- I was waiting for that version for Enterprise and missed that Desktop is available.  I'll give it a spin.
