Is there a way to create a bar plot to show the categorical variable `count`.
So, this question can or should be considered as a suggestion/idea, thank you.
Hi @Ed_ , if you were to click on the dropdown arrow next to your numeric field `floodfactor`, scroll to the bottom then you will see an option called 'Count of <dataset name>'. If using a specific numeric field, then only the following statistic types are available: Sum, Min, Max, Avg, Median and Percentile.
