ArcGIS Insights is not able to view the organization content
365
10-24-2018 09:27 AM
AhmadSALEH1
Despite that feature layers are  shared with the organization, nor the admin or the users are able to view the services in the add data page in ArcGIS insights!!
What might be the issue here?
Thank you,
Ahmad
AhmadSALEH1
After reporting this to esri customer support, after several tests we found out the this is a bug in ArcGIS online, and it appears when you disable the setting "Members can search for content outside the organization" if this setting was activated the items will show in the org tab.
BUG # : BUG-000119741
Synopsis : When adding data to an Insights card on ArcGIS Online, services shared with the organization are not displayed if the ‘Members can search for content outside the organization’ is disabled.
