Stairs Defined in Details not in Units
388
01-21-2024 06:24 AM
jauhari_mani
I was working on creating, indoors dataset from BIM file where Stairs are present in lobby under Details Layer and under Units layer it is marked as units.
What is the best solution to use have a transition route from those stairs as well.
Also, there are two stairs in one lobby.
Jinho_Kang
The staircase's area (polygon) would make sense to be in the Units feature.
The staircase designs (lines) should be in the Details feature.
Once you sort those two issues, then you should be able to proceed and design the vertical 3D transition line.
jauhari_mani
I need to define two rooms in my lobby having staircase as their use type in units layer and then generate my transitions.
