No Indoors Properties in Webmap with Properly Configured Layers
1699
9
07-31-2023 09:49 AM
LeviCecil
I'm trying to create a floor aware map in Portal (Enterprise 10.9.1) with the Indoors Pro extension. I have Units, Floors and Facilities, all properly configured with the Indoors schema fields in Pro. When I publish these layers to Portal, I'm not seeing anything in the map options for Indoors. I've published both as a webmap from Pro, and the layers individually, creating the web map in Portal and the issue persists. One issue I do have is that there is some missing geometry in my Units data at the moment. That's something we're chasing down in our FME CAD to GIS process. Could that be causing this?
Jinho_Kang
Hi @LeviCecil .
Can you please describe where and how ArcGIS Indoors License is deployed?
Ex) Is the Indoors Pro license deployed in ArcGIS Enterprise and used through the named user account?
       Or is the Pro license a single-use and activated in ArcGIS Pro only?
LeviCecil
The Indoors Pro extension license is through my named user account in the Enterprise
Jinho_Kang
Ok.... so eliminating the license deployment...
"I have Units, Floors, and Facilities, all properly configured with the Indoors schema fields in Pro."
Do you have the Levels feature class?
LeviCecil
Oh yes, sorry Floors is called Levels
Jinho_Kang
Hi @LeviCecil
Can you send me screenshots of
- ArcGIS Pro's floor-aware map
- Enterprise web map with floor layers + property tab UI
- Enterprise license's Indoor Extension
to jkang@esri.com?
MichaelJenkins
Did you configure the  Indoor Layers tab of the Map Properties dialog box?
GISP
LeviCecil
I did, yes
MichaelJenkins
In ArcPro, before you publish, do you see the Floor Filter widget?floor filter.png
GISP
LeviCecil
I do see that, yes
